Tri-Bar Light Upgrade - Auxiliary Running Light / Brake Light Question
05-02-2011, 05:29 PM
Purchased a Tri-Bar Light Upgrade - Auxiliary Running Light / Brake Light 67774-10 for my 2011 SG. When I installed it the flasher worked as a brake light and the brake light worked as a flasher. Simple plug and play so I called the dealer and they said it should work. Called HD and found out that this item does not work on HDI (International) bikes. I am sure it is a simple matter of moving 2 wires but which two. Anyone have the Electrical wiring diagram for the rear fender light.
05-02-2011, 06:28 PM
Sent ya a pm, but it doesn't look like you'll be able to enlarge it. If I send the pic in email you should be able to enlarge the jpeg. Let me know.
05-02-2011, 10:46 PM
Dawg can you please PM me the same jpeg? I have the same issue
Thanks!
05-03-2011, 12:15 AM
buy another bike here in the USA, so you can use it.
05-03-2011, 07:41 AM
Quote:
Originally Posted by
angelrod
LMAO. Thanks I would love to but MoCo frowns on that too.
05-03-2011, 10:39 AM
I would love to see what to do in this case as well as I'm about to install said light.
Cheers,
05-03-2011, 06:24 PM
Dbaudio
Thanks!
jpeg won't work in PM because you can't enlarge it. If you PM me your email addy, I'll email it to you and should be able to enlarge it
adamsrotors
07-16-2012 03:24 PM
trozenhorse
07-12-2012 10:40 PM
roccitybiker
07-09-2011 11:06 AM
moondog99
08-12-2010 08:06 PM
jtb4ever
09-19-2009 02:25 AM
brake ,
davidson ,
glide ,
harley ,
light ,
lights ,
play ,
plug ,
run ,
running ,
streetglide ,
tail ,
tribar ,
trilite ,
ultra
