Need help, my 2006 sg tail lights don't work.
Hope someone can help. I'm a long time listener 1st time caller. Sorry no pics yet but I will get there.
I have a 2006 SG, my tail and brake lights don't work. The blinkers work, and the trim light at the bottom of the fender works. I checked all the fuses, even moved them around just to be sure. the dash and front lights work. When I press the brakes the relay makes a clicking noise, I imagine thats normal. Any help would be greatly appreciated.
Thanks all
Thanks all
The OEM wiring of the rear turn signals is that they function only as turn signals; they don't operate as running lights. HD and others offer a module to have the rear turn signals operate as running lights and brake lights. Unless your bike has such a module, your rear turn signals are operating normally.
The tail light should operate as a run and brake light; but, I can't offer a fix other than use a test light to check the circuit at the bulb holder, and inspect for corrosion.
Hope you find a solution.
Carl
Carl
the rear brake light switch is to the left of your tranny cover it has to wire coming out of it. when i say check your fuse i mean the accessory fuse that controls your brake lights and turn signals.
