Hesitation and Sputtering
My dealer did all the checks including fuel pressure, compression, spark plugs, ignition coil. They weren't able to duplicate the problem....figures!!
I have run at least three tanks of fuel through her including putting HD's octane boost/injector cleaner in.
I know the Softails have an issue with the fuel line leaking in the tank. Has anyone ever heard of this on the Touring bikes? BTW, mine is an '07.
I hate the idea that this is probably going to take a long time to isolate. I can only hope that something finallly shows itself and breaks hard.
I plan to do some data recording with my Pro Super Tuner so I can use "Smart Tune" maybe it's a borderline air/fuel mix problem.??
if running with the cover off took care of he problem....the issue is with the cover on, you are sucking in hot air heated by your engine while standing still. the eng temp sensor sends hot engine signals to the ecm. ecm leans out the fuel. the heat levels generated by sucking in hot engine heated air causes a convention effect which results in a continual increase in engine heat, which the ECM tries to correct, by leaning out the fuel.
the fuel becomes so lean, that the engine will sputter and cough at power demands, like taking off.
once you move forward, ambient air gets sucked in which is a lot cooler than the air around your engine and this cooler air needs an ecm correction to combust correctly. the correction is done by the ecm, but the ecm can not anticipate this.
running with the cover off, allows more ambient air to be sucked in at a standstill rather than having the cover force the intake of hot engine heated air. The convention effect is reduced.
I'm planning to do some recording runs and use "Smart Tune" feature of my race tuner soon. The fact the the builder/tuner barely made adjustments from the base map while on the dyno leads me to believe I can do some good with some adjustments.
You can try to run with the cover off. Or if you have a parade fan, reverse the connections so that the air blows from right to left (cool air into intake) instead of left to right (hot air into intake).
I have been having some similar problems with mine. The only other thing is it gets hot FAST and then form time to time the bike is at idle then it drops to 500 RPM. The Speedo randomly cuts off.
Not sure if this the same issue. She does hesitate a bit and it is more form a stand still.
ANYONE have any ideas?
