Quieting down Reinhart True Duals
i just replaced my stock front pipes, and rear Kerker slip ons[ nice sound] with Reinhart true Duals, I like the feel and the sound, BUT after a long ride [like the other post have said] its a thump on the the ear drums, I dont want to wear ear plugs and cant see myself going back [i wanted O2 holes for my Thunder max O2 sensors] so what does work? Wraps drills bolts? like to hear from some success stories
I can hook you up with the number to the company that makes wild pigs. I'm pretty sure they dont make one with a 2" inlet but i think they would make you a set. I live 2-3 miles from the factory and they have done some custom work for me in the past. I had pigs before my Rineharts and they are MUCH quieter! Thats why i took them off.
Yes the system is brand new, I love the sound and tone but would like to take some of the edge off, I had Kerker slip ons before as seen in my picture/signature, The main reason for the true dual set up was 1. Oxygen sensor port's for my ThunderMax [yes i know i could weld some on] 2. sound, 3. looks. So i have been reading about mods to tame them a bit... keep the ideas coming guys and gals
I had Kerker slip ons before as seen in my picture/signature with factory head pipes, now I have [Bub]Rineharts True dual with 2" inlet mufflers, and find it to loud, it looks like Bub Stealth 7 is the only quiet 2" slip on available.
Update: I did add a Baffle from ??? cant think of the name right now and it reduced the noise by 6-8 db and took the edge off, BUT it also took the bottom end pull that i liked, so. Options are replace head pipes and put on my slip ons i had, $400-500, Or try the Bub 7 Stealths $500-700.
Keep this string going, Thanks Mark
I found the same problem with my Rinehart 2into2 pipes. After a couple days on the road they were just annoying as hell ! Pulled the baffles: was going to wrap (stock are NOT wrapped) but there wasn't enough clearance. Noticed the little louvers on the baffle pointed towards the end of the pipes. Reversed them (pointed toward header end) and it dropped the volume a little AND gained some performance from the back pressure. Been that way for about 2500 miles: no problems and I can stand the sound on longer hauls !
Good luck.
EDIT: By the way: I called Rinehart about the "Quiet" baffles and the rep flat out said they made no difference !
Good luck.
