Wild 1 577 Pic's
I like the ape hangers, been thinking about doing the same.
Question: All the bagger ape hangers have the bend in them to fit around the fairing, then they shoot straight up. I don't want them straight up, I want to pull them back so I can lean back on the bike instead of forward. Will the bend in the bars hit the gas tank?
billjoebob2002@yahoo.com (07-04-2021)
I ordered some WO577's today myself. Magnum cables are next. Were you able to use the same wiring on the throttle side? Some people say yes, some say no. What did you do?
ooopppssss...My mistake...I just looked at you photos again. You don't have TB
Last edited by Fat Mike; 12-18-2011 at 02:25 PM. Reason: Does not pertain to his bike..
I finished my install of 577s this morning and just got back from a ride. It is a lot of work but very much doable. The ABS made it a little more than I would have preferred but everything went back together fine.
As for wiring, I did not extend wires, simply routed them under the radio. Plenty of room to do that with the 12.5 bars. Since I have a CVO I understand that the TBW leads are longer than stock. Can't say if the TBW would be an issue on a non-CVO.
Feel free to let me know if I can give any pointers.
