Going Numb
I am not saying that the cycling solution will solve your problem, but it may help you understand the mechanics of what is going on as I think they experience these issues in a far more accute way.
It is generally accepted in the cycling fraternity that a "bigger, gel filled comfy" seat actually ends up aggrevating the problem - which is somewhat contrary to what you would expect. If you go in to most decent cycling specialist stores that have a special gel pad measurement tool which you sit on and it shows up 2 indentations where you "sit bones" are. You use this measurement to then size your saddle such that your sit bones are right in the middle of the seat.
If you took that measurement and looked at where your sit bones are located on your HD seat and then whether the seat is sloping up or down from that point it will help you formulate a way forward.
For the record, I suffered with this pain whilst cycling and had a fit shop measure me up and help select a saddle. The saddle they recommended was nothing like what I would have chosen had I not had their guidance. The end result - totally sorted and I can now ride am 8 hour day in the saddle without any pain.
As mentioned above as well, it is worth getting it sorted and checked out, long term damage can be nasty.
Some articles that may be of interest
http://www.nytimes.com/2005/10/04/he...on/04bike.html
http://www.bicyclinglife.com/practicalcycling/sore.htm
http://www.specialized.com/specs/spe...eometrysaddles
As stated earlier, not proposing that this is the answer, but may throw some insight in to the problem. For a start, it is a good possibility that your seat is not firm enough, which is somewhat counter intuitive
