90 degree valve stem?
I just installed a new tire and tube on the front of bike, now I am getting ready to purchase a tire and tube for rear, the stock stem that came on bike is a pain to check air pressure. Is there any reason I could not put a tube with a 90 degree stem onto the bike?
Thanks in advance
Thanks in advance
Saw this on Ebay and looks pretty good for the rear touring bikes:
http://cgi.ebay.com/ebaymotors/18068...fvi%3D1&_rdc=1
My Valkyrie has 90 degree valve stems from the factory. It also has clips that hold the valve stems to the wheels. I've been told more than once that if the clips break or are left off, that centrifugal force will eventually cause the valve stems to fail. So if you're going to install 90 degree valve stems, you need some way to fasten them to the wheel.
I bought these. Once my stock tires are done, which is pretty soon, I will get these installed with some new American Elites.
http://www.motorcycleanchor.com/
