Dakota Digital oil temp sensor location?
Old Aug 2, 2011 | 05:48 PM
johnica's Avatar
johnica
Default Dakota Digital oil temp sensor location?
Anybody mounted the sensor for a dakoa digital oil temp gauge anywhere besides the oil pan? From my experience and what i have heard the pan is not the most accurate spot. I was thinking in series with the oil cooler(on a 2012)...any ideas or pics of what you have done?
Old Aug 2, 2011 | 07:15 PM
SpiderPig's Avatar
SpiderPig
Mine is in the pan, not sure about the "not being accurate" part. Wherever you decide make sure that you attach a second ground wire around the outside of the sender to a good ground. The Dakota will act up if not grounded 100% and give you lower than the actual oil temp readings.
jackhis
Milwaukee Eight (M8)
Feb 24, 2018 09:19 PM
83hdfxrs
Shovelhead
May 13, 2017 05:03 PM
BornTexan
Mar 2, 2014 07:13 PM
harleycat225
Nov 8, 2011 12:31 PM
RandyD123
May 17, 2006 11:08 AM
