Try Your Luck: Diagnose 2007 EFI Intermittent High Idle & Stalling Issue
Old 08-05-2011, 05:43 PM
drspencer's Avatar
drspencer
drspencer is offline
Default Try Your Luck: Diagnose 2007 EFI Intermittent High Idle & Stalling Issue
2007 Softail Custom, 12K miles, Stage I & pipes (no Power Commander, etc.). That's it.
Bike ran great for the past 10K miles, not even a hiccup. With HD oil cooler, oil temps run ~200* and rarely get above 240*, even in the hottest of conditions.
Fresh plugs & all fluids 2K miles ago.
Complaint: Bike has an intermittent high idle. Sometimes you can snap the throttle back to normal RPM, sometimes not.
Also, this is usually followed by a low idle/stalling condition which occurs while stopped at a red light with the clutch pulled in.
At this point, when it stalls, you have to start the bike with the throttle partially cracked, and manually keep it running by working the wick, or else it won't stay lit.
The bike always seems to run fine for about an hour, then it gets hot and the problems show up.
Even with these issues present, the bike runs fast & strong with no misfiring, pops, etc.
1) Yesterday: Disconnected both throttle & idle cables. There is absolutely no mechanical interference when working the throttle body manually, nice & smooth throughout the entire range.
Cables lubed up and adjusted properly. Again, nice & smooth.
Throttle body thoroughly cleaned and IAC replaced.
After all this, checked for codes and code 'P0374 crankshaft position sensor not detected, cannot synchronize' was present in historical status.
Cleared code, rode bike, problem persisted.
2) Today: Checked for codes, none present.
Replaced crankshaft position sensor, bike ran great for ~1 hour, then same problems occurred (intermittent high idle, followed by low idle/stalling at red lights.).
What do you Folks suggest?
Thanks
Old 08-05-2011, 05:47 PM
onaride63's Avatar
onaride63
onaride63 is offline
TP sensor ? Worth a look
Old 08-05-2011, 05:51 PM
v2in's Avatar
v2in
v2in is offline
I think I would look for an intake leak. get some wd40 or the like, spray it around the intake and see if the idle changes. that's my guess
Old 08-05-2011, 06:00 PM
vistavette's Avatar
vistavette
vistavette is offline
Deleted my post: Sorry; I asked about the IAC and I now see you replaced it... guess I could read a bit more carefully!
Old 08-05-2011, 06:11 PM
hdramon07's Avatar
hdramon07
hdramon07 is offline
Check out this thread if you haven't already done so...good info here as to what has worked for others.
'07 Idle Issues
Since you've changed the IAC, my best guess would be the Throttle Position Sensor
Good luck.
Old 08-05-2011, 06:22 PM
drspencer's Avatar
drspencer
Originally Posted by vistavette
Do these bikes have IAC's? I think they do and I had the exact same issue with my '88 Corvette and that cleared it up. I'd check that
Yes, the IAC was replaced (as mentioned in the original post).
Old 08-05-2011, 06:33 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,770 Likes on 4,677 Posts
bad grounds. watch elect. connector corrosion as well
Old 08-05-2011, 07:13 PM
vistavette's Avatar
vistavette
Yeah; just saw that, missed it first time around
Old 08-05-2011, 08:35 PM
Uquackmeup's Avatar
Uquackmeup
Uquackmeup is offline
Is your oil level too high? Blow by in the air cleaner will cause the IAC to act like that even if its new.
Old 08-05-2011, 08:38 PM
drspencer's Avatar
drspencer
No, just right (slightly under full).
Quick Reply: Try Your Luck: Diagnose 2007 EFI Intermittent High Idle & Stalling Issue
