Ultra handling vs Dyna (Observations)
Just did a 7600 mile trip to the west coast on my Dyna, got home last Sat. Jumped on my Ultra Friday for a ride through South Beach and Key Biscayne after work and man what a crappy ride it was. I have Ohlins # 3 on my Dyna with a custom built internal set up on the font end, basically Ohlins springs with race tech emulators and a few custom machined parts to allow twisting of the springs without causing sticktion (sp), also have a mechanism on top of the tubes that lets me adjust the compression externally so I can switch from sporty riding to touring quickly. This is for reference to what I am now used to as of now.
Well I jumped on my Ultra and thought the steering head was about to fall apart, tires maybe under inflated, wheel bering going again, nope its just the shitty front end, there is a weak link up there and its between where the forks attach to the trees or the trees themselves. I tested play in the Dyna and the Ultra by violently turning the bars back and forth while sitting on the bikes, there is three times more play in the Ultra between the bars and the wheel turning, I have to think this is caused by the weak trees on teh ultra, not so much as week but the design is different, it only pinches at one point where the Dyna pinches laterally on two points on each leg. Not biching about my Ultra just an observation, put a couple hundred on it in Miami traffic and am used to the handling again. I will say this , the Ultra brakes are light years ahead of the Dyna.
I have been looking into the 'Tour Trac' for my 08 Glide. I spent 4800 miles battling a high speed wobble the would show up between 80 and 90mph. Recently my buddy was test riding it for me and almost lost it in a curve because of the this issue. I have tried the 'Tour Link' and the 'Smooth Rider' solutions, Changed Tires, changed Suspensions, Re-torqued the neck bearing bolt multiple times, but I still get the same problem. I have decided to spend the big money and get this product to see if it corrects my issues. Would like to know if anyone else has had luck with this product but I am will to be the guinea pig if need be. I guess it is a good thing to see that the newer bikes are having steering head issues also... Does anyone know if the 09 Triple tree is the same as the 08?
