Let the teardown begin (cam swap)
Well after months of thinking about the whole cam swap project I finally got off my ass and decided to do it. The labor was holding me back because its expensive and I don't trust people. With all the posts on here and the fact I only needed to buy a few tools (to replace the bearings) I think I'll be OK. While I'm not a mechanic I'm not an idiot either. I figured the SE compensator swap went off without a hitch so this should be no different.
Cam choice is the worst decision to make. Everyone has their favorite and opinion. There's a dizzying array of choices. Once you decide on a cam you read something that makes you second guess yourself. I believe if you stick with the popular ones there really isn't a wrong choice. I figured if I do the swap myself and I don't like it then I can just take it out. So I decided on a Cyclerama 575 cam. I saw some reviews and dyno charts and in my gut kept going back to that cam. The other option was a 555. The dyno charts I saw showed the 575 to come on a little sooner than the 555 and had over 100ft.lbs of torque from 2-5K. I'm also installing a Dragos SCS 2 into 1 header that should add some decent power too. I sent the ECM back to Revolution Performance for the reprogram so we'll see how well the EMS system works with this set up. Andrew doesn't think there will be an issue. I debated about changing the lifters though. Some say you can leave the stockers while others say they already have a wear pattern and should be replaced. I have over 10k miles so for the $150 and extra hour labour I figured I'd replace them (only for piece of mind). My goal is to get at least 90hp and around 100ft.lbs of torque when I'm all done. I'll keep everyone updated on my progress. Wish me luck :icon_smile: Joe |
I thought that after the initial install of the EMS tuner you would not have to have the EMC flashed again unless you added more cubic inches to the motor??
For a cam change its required-at least that's what they told me.
good choice , you'll love the cam and Frank's 2-1 will wake it up also
So far so good! Got the pushrods cut, cams out and bearings replaced. This is EZ (so far). Georges tools worked great and will soon be in the for sale section to recoup some of the dough for the project. Cams, lifters and ECM arrive tomorrow. Saturday morning the 2 into 1 headers arrive and Saturday night I should be smoking the tire :)
take a good look at your oil pump while you have it out. if you see scorn areas on the cam plate, you might want to check your crank run out while you have the plate off.
i might be interested in recycling the bearing tools for you.
Just had mine changed out yesterday, Feuling 525's, Feuling race lifters, SE Adjustable Pushrods w/the grade 8 machined steel locknuts, Torrington bearings, and a new Auto Tuner that is now dialed in to work with the PC-V and a kick ass map from GAZRNR who has the same cams that I do. By the seat of the pants I'll say WOWOW!!
I'm not real keen on the dyno's as I feel it puts about 5000 miles of wear on your bike in a couple hours, and besides that what I bought the Auto tuner for. |
Where do you buy the locknuts? I'll likely pick up a set to have on hand just in case.
Originally Posted by lionsm13
(Post 8797280)
© 2024 MH Sub I, LLC dba Internet Brands
