my 2011 road glide ultra came with mirrors that i cant see past my arms when looking in the mirrors im thinkin for safety reasons harley should put on some extended mirror upgrade for free hmmmmm never happen
Mirror extenders work great! They are designed to raise your mirrors about 2 or 3" up. I had that same problem because my shoulders are so wide, then installed them, see fine now. I also added some little adjustable spot mirrors that you can get at Harbor Freight for $0.99 and put them on the inside edge since that is still just all shoulder view, now I don't have any blind spots even 6" to my rear. Or you can do like my son and buy the mirrors that have the longer arms than the stock ones do, they only raise your mirrors a little but extend them out further to the sides.
Being a wide body, I had the same problem not being able to see. When I bought the new limited, I had then put on the split vision mirrors. So much better.
You might consider these mirrors from Kuryakyn. They position about one inch longer than the stock mirrors. I think they are called the Magnum or something like that.
