Progress Pics of Stage 2 103 build on my 2009 FLHX
Old 09-21-2011, 01:48 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Default Progress Pics of Stage 2 103 build on my 2009 FLHX
Just wanted to post pics of my Stage 2 103 build in progress on my 2009 Street Glide. The heads are out getting ACR solenoids installed.
Shawn
ENJOY!
Old 09-21-2011, 01:58 PM
Indianspringsaz's Avatar
Indianspringsaz
Indianspringsaz is offline
Right on. Keep them coming.
Old 09-21-2011, 02:00 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Cool pics. Thanks for sharing. How many miles did you have on her and how bad was the carbon build up, particularly on the valve stems? I've been seeing heavy carbon build up in many of the later model bikes. Not sure if its the gasoline, amount of oil being sucked in by the later breathers or what. I've seen heavy carbon build up in some engines with only 5k on the clock. All later models.
Old 09-21-2011, 02:11 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Anticipation has got to be running high!
Old 09-21-2011, 02:14 PM
XARAN's Avatar
XARAN
XARAN is offline
Shawn
Im thinking about doing my Glide, what cams are you using?
Old 09-21-2011, 04:07 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Rickr01,
This bike is pretty much new. Not many miles on it at all. This is one of our showroom demos so it doesn't get out much. There is some carbon buildup, but that is to be expected with the combustion that takes place in the chambers.
XARAN,
SE 255 cams.
Shawn
Here are more pics:
Carbon Buildup:
Cams about to go in:
Showing difference between stock oil pump and Screamin Eagle high flow oil pump, Screamin Eagle oil pump is on the left:
Showing other side of oil pumps:
Screamin Eagle Billet Cam Plate vs. stock cam plate:
Screamin Eagle Billet Cam Plate with cams mounted:
Old 09-21-2011, 09:32 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Looks like this just turned into a Stage 4 103 build. SE stage 4 heads are on their way!
Shawn
Old 09-21-2011, 10:33 PM
gump305's Avatar
gump305
gump305 is offline
That cam plate looks so much better and rigid than the stock. with that new oil pump everything should be nice and lubed up, really nice build.
Old 09-21-2011, 10:54 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Looks like the rings never got seated by the looks of how clean the top of the piston is around the edges...
Old 09-22-2011, 06:58 AM
HighLiner's Avatar
HighLiner
HighLiner is offline
Where do I get my "Dr V twin" t-shirt?
Quick Reply: Progress Pics of Stage 2 103 build on my 2009 FLHX
