Extended Brake and Shift Pedal longer than 1" ?
I used Walter Work Shop on my 05 and I think he does 1 or 2 " extentions.
On my FLTRX I went Kuryakyn and its about 1.75 longer. The picture is with floorboard re locators on that moved the floorboard forward 1" from stock and the pedal is in front of the floorboard and out of the picture
the Ness floorboard extensions I had on my FBL moved the boards forward by 3"...they're the same ones I plan on putting on my RKC, supposedly they will fit. The best thing about them was that they moved the actual controls also, both the shifter and brake pedal moved 3" forward. I didn't need to buy an extended shifter and brake pedal. For outward movement I used a set of Harley Goodies and the fit was perfect, very comfortable. The kit even came with the new extended brake line.
Thanks, but,
I don't think that setup will work on a newer Touring Bike.
Thanks for the pic!
Looks like one added benefit from doing this, is that by moving the Boards forward, you have extra room when you need to "walk" the bike.
FirstRealBike
09-22-2008 11:45 AM
Cannon00000
06-01-2007 08:25 PM
