EZ-UP center stand
Old 09-29-2011, 07:46 PM
mjb765's Avatar
mjb765
mjb765 is offline
Originally Posted by '05Train
Had one and hated it. I felt it was unstable, unsafe, and poorly designed.
I had one that was unstable and I spoke to the owner and it turns out since the bike was lowered it was not the correct height. He sent me antoher one and all is good. If you have any changes to your bikes ride height, the stand has to be changed to accomodate it. Maybe that's the issue. Mine is very stable and easy to use.
Old 09-29-2011, 07:58 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
i like mine, on mine the floorboard scrape b4 the stand,it will hit speedbumps when 2 up,only one issuie,if it is parked on even a slight downhill it can pop right off the stand.
Old 09-29-2011, 09:33 PM
mjb765's Avatar
mjb765
mjb765 is offline
One of the big things with any center stand is it must be used on LEVEL ground!!
Old 09-29-2011, 09:41 PM
cmc seabee's Avatar
cmc seabee
cmc seabee is offline
Default EZ-Up center stand
Thanks folks for all the replies. I guess I'm just being a little too cautious.
Don't want to dump my bike; takes too long to heal up at my age. Ride safe and thanks once again.
Old 09-29-2011, 10:01 PM
tmans's Avatar
tmans
tmans is offline
I have one on my '09 ultra. I like it very much - love to see my bike level in the garage every morning. However, I scrape it all the time - speed bumps and while cornering. May have to reluctantly remove it.
Old 09-30-2011, 06:30 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Wink
Originally Posted by mjb765
You won't need a True Trac on the new frame
That's going off topic! New frames still have rubber mounts and are better, but not perfect.
Old 09-30-2011, 06:31 AM
grbrown's Avatar
grbrown
grbrown is offline
I have had a display stand for many years, mounts up front and tucks under the floor boards. Doesn't cause any grounding problems, nor does it interfere with my True-Track!
Old 09-30-2011, 06:40 AM
Cougar1959's Avatar
Cougar1959
Cougar1959 is offline
First thing I bought, when I got my 2011 UC. I scape it every once and a while on large speed bumps and in tight curves, 2 up. Just got back from the Tail Of The Dragon and I think my EZ-up, left its mark, on just about every curve. Just scrap marks on the legs.
Still works great.
Old 09-30-2011, 07:11 AM
luisan's Avatar
luisan
luisan is offline
I have one on my 06 Ultra along with a Progressive brace,no interference whatsoever and only an occasional scraping once in a while.Love it!
Old 09-30-2011, 03:24 PM
mjb765's Avatar
mjb765
mjb765 is offline
Nothing in this world is perfect...but after going over all the same places that my 06 used to wobble, my '10 & '11 do not wobble even at a higher speed. Haven't found the need for the True Track on the new frame yet.....
Quick Reply: EZ-UP center stand
