Larger gas tank
you could search for a custom tank, the stock tank is 6 gal. giving a fuel range of about 250 miles for most of us-- over 300 miles if you stay at 55 mph.
auxilary "gas can" type things are available incl the $30 unit that fits in a saddlebag. or some guys strap them on the tourpak
I've shied away from those because of the fear of a wreck.
mike
mike
I used a 5 gallon Tour Tank on my last bike (carbureted). It looked like I was hauling around a keg, but it did the trick. I'm unsure whether or not I can easily plumb it into the fuel system on my current bike. Once I determine that I can, the it will be on my Electra Glide. Since it is about the same thicknes as the OEM tank and equally exposed, I figure that in a wreck, gasoline would be my least concern. If interested, you can google "Tour Tanks" to see what they look like.
auxiliary "gas can" type things are available incl the $30 unit that fits in a saddlebag. or some guys strap them on the tourpak
mike
mike
I have never had any problems and there was never any Gas Smell in the saddlebag nor on my clothes.
I investigated larger tanks a couple of years ago. There are several custom options available with around 7 gallons, from Motorcycle Metal, RWD, FatKatz, but they are all expensive. There is another possible option worth looking into, from viigastanks, who widen stock 5 gallon tanks and may be able to do the same for later stock tanks.
