Front Caliper Brake bolt torque
Old Oct 21, 2011 | 10:38 PM
SamB's Avatar
SamB
Default Front Caliper Brake bolt torque
Does someone know what the front brake caliper bolts torque is? This information request is for an 09 Street Glide.
Thanks, Sam
Old Oct 21, 2011 | 10:46 PM
Ticitme's Avatar
Ticitme
28 to 38 ft lbs by my 2011 manual. I'm assuming that they are the same spec
Old Oct 21, 2011 | 11:08 PM
SamB's Avatar
SamB
Default Torque
Thanks for the quick reply. I am sure the 09 and 11s are the same.
Sam
Old Oct 21, 2011 | 11:14 PM
PistonPuller's Avatar
PistonPuller
Same. Copied right out of the 09 Touring manual
Brake caliper (front) mounting screws 28-38 ft-lbs 37.9-51.5 Nm
Old Apr 11, 2014 | 05:59 PM
longmore's Avatar
longmore
1st Gear
Default Front brake caliper pin torque spec
What is the torque spec for the front caliper pin on a 2008 ultra?
Old Apr 11, 2014 | 06:31 PM
Beav's Avatar
Beav
Exclamation
I paid 60 bux for my manual, it's saved me THOUSANDS!
I'm also pretty sure I didn't get the last one, or that they quit makin' them...
Old Apr 11, 2014 | 06:33 PM
UppercaseJC's Avatar
UppercaseJC
Now that you spent the $60 you can use it to help others instead of being an azzhole
timbo141's Avatar
timbo141
Install a new pad pin and tighten to75-102 in-lbs (8.5-11.5 Nm)
Old Apr 11, 2014 | 06:41 PM
qtrracer's Avatar
qtrracer
Use a combination wrench and you don't need a tq wrench. Try it once. Check it with your tq wrench and see.
Old Apr 11, 2014 | 09:02 PM
Beav's Avatar
Beav
Afford a touring bike, but can't buy a manual? Not much help for those who won't help themselves...
Besides JC, I did help. Maybe (hopefully) the OP will go get one. If he's relying on answers from the e-net, he's got bigger problems than taking a razzing about a book.
Read my sig... sometimes those 3 are hard to distinguish from each other.
