LED's Installed On 2012 Electra Glide Limited
LED's Installed On 2012 Electra Glide Limited W/Video
Just finished installing Ride Time Technology LED Progressive Scan Tour-Pak Lights, LED Rear Fender Tip Run/Brake Light, LED Front Fender Tip Light With Smoked Lens.
Kuryakyn Panacea LED Rear Tail Light, Panacea Rear LED Turn Signals, Panacea Front LED Turn Signals all set to run in Panacea Mode On The Panacea Controller Unit.
I like the setup and hope it will keep the dumba$$ from running into me......I know....good luck with that.
Short YouTube video if interested:
http://www.youtube.com/watch?v=QAdBeS63gjM
LEDs Yes
Hawg, great minds and all that....
I had the Kury LEDs and Panacea set up on my Heritage... loved 'em;
took 'em off and put 'em on the Ultra and they are great there as well;
added the LED brake/turn rear fender tip; moved the LED run/turn mirrors from the Heritage to the Ultra; like the incandescent front fender tip -- left it OEM; lookin' at a couple more LEDs for the rear... the next one for me is the tour-pak LED (got the run/turn/brake incandescents now), but want to move to the LED funtions... I like your progressive look.... hmmmm...
The one thing I would recommend if you are going to install the Ride Time LED's is to use a hot blow dryer or heat gun on low. I used my heat gun on low and took my time heating the red lens. Working from the outside of the red lens I slowly pried the red lens loose from the inner most corner. I kept the heat going on the lens until it popped off. I heated up the black goop on the red lens before reinstalling the lens and it resealed itself.
As I said, it's really pretty easy.
