Starter Engages While Motor is Running
Pull the start relay and see if it quits running the starter when you pull the lever. If this drawing is correct I would disconnect connector 5 and see if you have continuity between the output of the Brake switch and the output of the start button. If you don't find it there check from 5B to 1B, then on 1A.
Ricochet59
11-04-2012 04:35 AM
kingkingking
09-29-2009 06:28 AM
