09 starter problem
Old Aug 23, 2009 | 07:42 PM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Default 09 starter problem
At 3200 miles my 09 Street Glide starter switch seems to be stuck in the start mode. It engages the starter everytime I pull the clutch in to shift. When I take it in to the dealer what kinds of things should I be expecting them to change out? I'm worried the starter will now have abnormal wear on the starter gear and whatever it mates to. I suspect this is a problem with the starter switch on the handle bar rather than the starter itself.
I noticed the problem this past week once and thought I had hit the starter button, but it almost caused me to dump the bike. When I turned on the master switch it tried to start in gear and clutch out.
Old Aug 23, 2009 | 08:30 PM
widowmaker221's Avatar
widowmaker221
Starter solenoid is stuck engauged (the cause will need diagnosis).The starter will have excessive wear from this as it is probably engauged at all times.I would not ride the bike in this condition as it is unsafe and could lock up on you.Sounds as you have been riding it this way anyhow so if dealer is close just take it easy if no tow is available.Good luck
Old Aug 23, 2009 | 08:40 PM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Just started tonight on the way home only about 3 miles from home. Before that was just the one time it engaged when first starting the bike and quite after started. I agree probably needs towed in to avoid more damage and dangerous lock up.
Old Aug 23, 2009 | 09:08 PM
Bonesbike1's Avatar
Bonesbike1
I had that problem on a WG I had and just pulled the wire off the starter terminal after the bike started and then rode it to the dealer. If yours has the plug on the starter motor you might try pulling it and see if you can get it to the dealer. Turned out that my handlebar switch was bad.
Old Aug 27, 2009 | 09:21 AM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
New handlebar starter switch fixed the problem! They said the starter gear was not damaged. I suspect I'll have to complain about the starter just before it goes out of warranty to make sure it wasn't prematurely worn.
Old Jun 18, 2013 | 08:36 PM
cnnesseth's Avatar
cnnesseth
I have a 2010 flhx which is doing this and am trying to find the part number for start button do you know the number?
Will CF
Sep 15, 2018 01:45 PM
jlasoftail
Jun 27, 2014 11:51 AM
eng23ine
Jun 18, 2013 08:30 PM
Ricochet59
Nov 4, 2012 04:35 AM
kingkingking
Sep 29, 2009 06:28 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
