loud tick...help
Old Jan 4, 2012 | 04:25 AM
sanaga's Avatar
sanaga
Default loud tick...help
bike is 2011 Limited
just installed S&S 583 easy start cam
2 into 1 VH ProPipe
Big Sucker
PC5
after installation the cams, load map from pc5, bike runs very nice and pull alot stronger in the middle rpm.....im satisfied at this point
my only problem...when the bike idle, if i suddenly whack the throttle, it will sound loud CLICK before the rpm rise quickly.....
mayeb its a detonation/ping ?? i cant identified a ping so im not sure its a ping or not
anyone guide whats happen with my bike?
fuel is 92 ron...thats highest on my village ....its an ancient country guys
is it dangerous?
bike really run very nice and stronger after cams
maybe becoz cams installation i need to use higher RON fuel ?
or can i add more fuel through pc5 at certain rpm/certain throttle opening ??
dont suggest me to dyno tune, coz NO dyno tune available here....
btw i appreciate ur input
thanks
regards
adhi
indonesia
Old Jan 4, 2012 | 05:06 AM
Scottybob's Avatar
Scottybob
Ill let the experts give you advice. I'll give you my experience. U had a pinging and changes to high grade fuel and no more ping.
Old Jan 4, 2012 | 07:20 AM
Thumper1's Avatar
Thumper1
Sounds like a ping based on your description. Probably simple ignition tweak in the map. Contact Fuelmoto for the adjustment needed. Their the experts.
Old Jan 4, 2012 | 07:24 PM
sanaga's Avatar
sanaga
Thanks scotty...
92 is highest here
How about add some octane booster can help maybe?
Tia
Old Jan 4, 2012 | 07:27 PM
sanaga's Avatar
sanaga
Soo now confirm its a ping....thanks bro
I dunno about ignition tweak, thats why i dont touch the ignition table
Fuelmoto if u can help, i appreciate, many thanks
Old Jun 13, 2012 | 06:46 PM
bknibb's Avatar
bknibb
Default Same here Sanaga
Brand spanking new Road Glide Ultra (103). Wasn't happening at first. Now past the breakin mileage and same deal: only when at idle and give her a goose a LOUD ping. Not every time, maybe 10%. Trying to use deductive reasoning on symptoms....
Old Jun 13, 2012 | 10:50 PM
pittz5's Avatar
pittz5
Hows your valve train noise with the 583? Just upgraded everything to the 106 with 583and I hear noises at idle I never heard before. Pretty disappointing. Im starting to think it may be the injectors but cant tell. Sounds like a knocking in rockers. Have had several mechanics ride it and they dont hear anything to be concerned about. I really didnt think the 583 would be noisy. glad you figured out your issue though.
Old Jun 13, 2012 | 11:44 PM
2black1s's Avatar
2black1s
I'd have to disagree with the all of the ping diagnoses based on your description "my only problem...when the bike idle, if i suddenly whack the throttle, it will sound loud CLICK before the rpm rise quickly....."
When you say "whack the throttle" are you talking about about free revving in nuetral or with the clutch disengaged? That is how I interpret what your saying. If so, that is why I disagree with the ping diagnoses.
A ping is most likely when the bike is under a high load. Going uphill in too high a gear/too low an RPM is an example of where a ping would become obvious. Rarely would you ever hear a ping under light loads such as free-revving. Additionally, pinging is rarely described as a "CLICK". Maybe a series of "CLICK, CLICK, CLICK...", but not a single "CLICK". It's more of a rattling sound than a click sound.
As hard as it is to diagnose noises over the internet, based on your description I think you're going down the wrong path if you believe your problem is a pinging issue.
Old Jun 15, 2012 | 06:44 PM
TUCCI's Avatar
TUCCI
Having a cam changes everything when it comes to diagnosing engine noises. Hey 2black1s how was the visit to the homestead are ya back home yet?
Old Jun 15, 2012 | 08:06 PM
scarygt's Avatar
scarygt
I had what sounded like detonation.. Turned out to be the doors on the leg fairings... Vibrates when idle and letting off throttle after hard acceleration. I had to remove vents to determine that they were the problem. It's worth checking. Good luck!
