I have a 07 street glide with rine heart true duals and a big sucker air cleaner. I was told there was a power commander but can't seem to locate it. I have looked both side covers and under seat. I keep at about every 1000 miles a p1357 code which is intermittent front cyclender combustion. I took off spark plugs today and took picture if I can post on here I will using mobile version.
The dealer will always recommend the HD Tuner. Get in touch with FuelMoto, at the very least they will give you some sound advice. If you buy a tuner from them, you will recieve liftime technical support.
Indy installed unit under right side cover but put controler under seat just behind fuel tank where i had to stick my hand in to find it if i wanted to change the map.
