Setting the PIN for the security system
It also seems to be somewhat confusing by reading in the owners manual.
Is there a simpler way to do it? or could someone put it in laymans terms?
Maybe just start over, erease the old PIN if in fact he did add one and enter a new one?
to check your current pin:
with fob present (wont work otherwise
)....turn your ignition, on, off, on, off, on
press left turn signal switch 3 times
press right turn signal switch 1 time
your current code will be displayed in the odometer. at this point, if you want to change it, then you use your left turn signal switch to cycle through the digits. if you accidentally pass your desired digit, don't worry, just keep hitting the switch till it comes back around. the right turn signal switch is like the 'enter' button. it will select that digit and move to the next position. after you get all 5 set, just turn the ignition off
also, it isn't a bad idea to practice using the pin a few times until you get it down pat. nothing like the frustration of not being able to enter your pin when you really need it.
there should be a couple of cards in the back of your owners manual with some easy instructions on how to. i carry mine in my wallet with the numbers on it, just in case.
I have a deathly fear of loosing that big round key bob thing. I have studied the procedure and took the card that is in back of the owners manual and put it in my wallet...
I also carry the key/Key bob thing around my neck on a lanyard under my shirt.
It is gonna happen to me...since I am so focused on it...
https://www.hdforums.com/forum/touri...r-v-twins.html
