U-Haul: smallest enclosed trailer for Ultra transport cross-country?
Old 02-11-2012, 09:58 AM
albngore's Avatar
albngore
albngore is offline
Default U-Haul: smallest enclosed trailer for Ultra transport cross-country?
U-Haul has 4'x8' and 5'x8' enclosed single axle trailers, no ramps. I know they also offer the open trailer with a short ramp and that one has good tie-down capabilities. I don't know if the enclosed trailers have anything to tie to. I will be hauling the cycle behind a F-150 pickup.
Your recommendations?
Old 02-11-2012, 10:17 AM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
You better do some measuring because the Ultra is all of 8' long, it would probably have to go in at an angle to fit. Open trailer will pull easier, just depends on what kind of weather you run into.
Old 02-11-2012, 10:23 AM
GSHOG's Avatar
GSHOG
GSHOG is offline
How far are you going? If the trip can be done in a day I would use the open trailer. I have used it before and it does the job and is cheap.
A friend has used the 5X8 to haul his '09 UC and that worked well.
Old 02-11-2012, 10:29 AM
jjnoble's Avatar
jjnoble
jjnoble is offline
I have a 5x8 and it works perfect for one bike. (open trailer, not enclosed)
Old 02-11-2012, 10:33 AM
rrsjs5's Avatar
rrsjs5
rrsjs5 is offline
None of the enclosed trailer's have tie down's good enough to secure a motorcycle
Old 02-11-2012, 10:37 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
depending on how much you care, I would strongly suggest a dual axle trailer with brakes.
The trailers I see most often flipped at the roadside are single axle "utility" types- a tire, hitch or bearing problem ( or panic braking) and all of a sudden it changes.
Or put the bike in the truck bed.
Mike
Old 02-11-2012, 10:39 AM
lksmitty's Avatar
lksmitty
lksmitty is offline
I hauled my Ultra with the Uhaul open trailer for 2500 miles....worked like a champ. Your bike is centered behind the tow vehicle and the low side panels on the trailer do a good job of deflecting rocks, etc. so you don't have to worry as much about anything hitting your bike. You can also buy a bike cover to deflect rocks that is tight to the bike....I saw them at a motorcycle show recently.
I left mine out in the open and didn't get hit with anything from the vehicle.
Old 02-11-2012, 10:42 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
don't cover a towed vehicle if you like the paint.
the cover moves, the paint gets scuffed
Mike
Old 02-11-2012, 10:45 AM
cdemarse's Avatar
cdemarse
cdemarse is offline
Also if you are going to use one of the enclosed trailers dont tell them you are using it to haul a bike. Not designed for it and will or can refuse rental.
duckf5 (10-07-2021)
Old 02-11-2012, 11:04 AM
leohd's Avatar
leohd
leohd is offline
if you really want enclosed I heard of people putting eyebolts in the floor and then removing em and replacing with bolts when they return it
duckf5 (10-07-2021)
Quick Reply: U-Haul: smallest enclosed trailer for Ultra transport cross-country?
