OEM 180mm Tire Install on a '07 or '08 - A How To
  #101
Old 10-13-2015, 05:05 PM
Recycled's Avatar
Recycled
Recycled is offline
Originally Posted by Hafi1050
Thank you for all the perfect documentation and photos!!
I have only one question:
For the mod i have to change the belt to 140tooth? Or am i wrong?
Hafi
No, the stock belt can be re-used. Don't forget, because you are replacing the legs of the swingarm, you can make them whatever length you need. For example, a trans pulley change to a 31T or 30T may need a different length of swingarm to maintain acceptable adjustment parameters.
  #102
Old 10-13-2015, 06:34 PM
jaxdwg's Avatar
jaxdwg
jaxdwg is offline
Originally Posted by Batman7349
I have to agree with you 110%, because you can!!! Great Job
What he said
  #103
Old 01-05-2017, 04:56 PM
lscivil's Avatar
lscivil
lscivil is offline
Stage I
John what sparket did you run on the front, as far as an off set?
  #104
Old 01-06-2017, 08:57 AM
jmaniace's Avatar
jmaniace
jmaniace is offline
You don't need to change anything the front pulley is wide enough to let the belt ride a little to the left. Look up timberland here are some links that helped me do mine.
https://www.hdforums.com/forum/touri...0-install.html
https://www.hdforums.com/forum/touri...rlier-flh.html
This mod took me a while to complete and I prepared for a year before starting.
  #105
Old 01-06-2017, 09:42 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
Wink
Originally Posted by jmaniace
You don't need to change anything the front pulley is wide enough to let the belt ride a little to the left. Look up timberland here are some links that helped me do mind.
I'm running a 1 1/8" belt on my 1990 Glide, with a later spec wheel and pulley, which spaces the belt out further. The front pulley is much wider than the widest belt, which is jolly good of H-D, so we can tinker!
  #106
Old 05-04-2020, 12:04 PM
Travisdixon 91's Avatar
Travisdixon 91
Travisdixon 91 is offline
Stage II
Default 2006 king
Originally Posted by JohnCA58
Trying to understand why your modifying the swing arm, I am using a 08 swing arm (02 - 08 are the same) on my 00 RK with a 180/55/18 tire and 5.5 rim, with a chain drive (530) which is a little over inch wide. you could also run the one inch belt without doing mods to the swing arm and center the wheel between the fender, I am using a 09 fender that was narrowed to fit between the older frame rails and also made my own metal fascia.
You posted this a long time ago. I just picked up a set of enforcer wheels for my 06. Was wondering if you could give me a little more details on how you done this conversion.
  #107
Old 04-16-2021, 04:47 PM
UncleAlRides's Avatar
UncleAlRides
UncleAlRides is offline
Stage I
Road Captain,
Are you still out there? I stumbled on to your thread about installing a 180mm on your '07 FLHP in 2011. I just finished putting a 180 on my '03 Road King. However, I didn't change the swingarm. The setup works fine but tire install and removal is a pain so I want to modify a '02-'08 swingarm. I really like your approach and would like to learn from your mistakes rather than repeat them, You comment about "a bit of difficulty fine tuning the camber of the rear wheel" caught my attention.
  #108
Old 08-02-2023, 12:49 PM
Bdupre10's Avatar
Bdupre10
Bdupre10 is offline
Stage I
Default Swing arm fitment
Originally Posted by Recycled
I had originally expected to modify the 2010 fender to fit but didn't because it would have resulted in a very poor fit. Any water or road dirt would have been slung past the areas not covered by the 2010 fender.
The solution was to use the 2007 fender as it already fit the chassis. I did away with the original mounting hardware and simply welded captured nuts in the original mounting slots in the fender. This makes it wide enough to clear the 180mm tire with a good margin of clearance but by doing this the fender had to be cut lengthwise in half in order to mount it.
Then, the rear section of the 2007 fender was cut off at the center point of the struts. In one of the pics you can see the piece that was removed.
Now it was just a matter of making preliminary cuts in order to lay the section of 2010 fender to be grafted over the 2007 fender and tracing it.
Using a jigsaw with a metal cutting blade made it easy to cut the 2007 fender so the 2010 section would butt perfectly with it. A small strip of metal had to be butt welded in the center section of the front lower part of the fender because the 2010 fender was too short.
The metal HD uses for their fenders is a heavy enough gauge that it is a joy to weld, even when butt welding. A beginner can do it by applying short bursts, spot welding with a mig welder. Take your time and prevent overheating and distorting the metal by staggering the spot welds until the entire piece has been welded.
I use an assortment of hand held heavy copper implements as a backer to prevent burn through by absorbing excess heat while welding. This also allows you to fill any voids with new metal. The weld will not attach itself to the copper. I use nozzle dip on the copper.
Just weld, grind the high spots, add more weld where it needs it and before long you will get it right, a one piece hybrid fender that fits perfectly.
The only downside was, I could not sell my 2007 fender since it was sacraficed to create the new one.
I picked up a set of wheels tires and axles from a 2011 road glide and was able to get a swing arm off the same year bike I am wondering if the 2011 swing arm will bolt up to the 2007 ulta classic frame to make the swap easier any help would appreciated im planning on attempting to do the swap this winter
speakerfritz
06-27-2012 10:56 PM
TexasHarleyBoy
03-13-2012 07:32 PM
deleontow
09-28-2010 09:58 AM
jtmurph00
03-17-2008 08:59 PM
jakazz
02-06-2007 09:41 PM
Quick Reply: OEM 180mm Tire Install on a '07 or '08 - A How To
