Flare an OEM windshield
I have the stock height windshield on my 2010 RKC. I'm 6' 1" and I easily look over the top of it. I used my fingers as gauges to see how short my shield is to my height. I started by sitting on my bike with 1 finger (not that one) pointing straight forward on top of my windshield, I could still see over it without any problem. I did the same thing with 2 fingers and could still see over it. I held 3 fingers out and my line of sight is falling right inline with the top finger.
I swapped my stock windshield with my buddy's (2008 Road King Police) bike which has a taller windshield for a few weeks. I see over it just below my line of sight. It does keep the wind off of my much better than my stocker, but I don't like the look of it. It is way too tall in my opinion.
Has anyone tried to use a heat gun and some round stock to flare an OEM windshield?
Just buy one. Mine worked -- I lit a cig with a Bic at 35MPH once. But it wasn't pretty - And it wasn't the first one (honestly, I don't remember how many "blanks" I went through to get a usable prototype - Only to find out later that others were probably prototyping with better tools than I).
LRS makes some good stuff (I have a couple of their flares and use their Ultra-Flip regularly). And they don't charge an arm and a leg either.
THAT SAID - If you just gotta try it -- You want heat - Plenty of it. Adding a curve is MUCH easier than adding a "flare" -- You're going to go back and forth and back and forth at just sort of a "slow swaying" speed (maybe once across in about four seconds) just an inch or so below the top. The cue is when the plastic turns sort of a milky white. QUICKLY put down the heat gun and apply pressure from the rider's side to the front side using both hands - one on each side of the plastic, so you're applying pressure from the rider's side and resistance from the front side.
Don't stop moving - Smooth motions, no exceptions. The plastic will take "prints" from the gloves if you stop or "skitch" across the surface.
And then when you find out how well it works -- Believe me, it makes a rather dramatic difference -- go buy one that looks nicer.
Received 70,866 Likes
