pcv
Anyone using a pcv on 08 Ultra? Just put one on..seemed fine but, after riding awhile today seems the front cylinder is less strong than the rear..exhaust sounds different..
14 trouble code something not right,check the o2 sensors on the 08 they should be unplugged and terminator caps should be in the end of the wires,different years are diff may have had some confusion their.next would be to check the main plug,one bent pin can cause problems,also make sure u have the correct model pcv.
Pcv came with the o2eliminators..they are on...the map I see they put on says 09, stock air stock pipes...may be the issue...no maps for 08 listed..and 09 has no options with vh bs true duals..that much different between 08's and 09's..
PC-V on a bike older than 09? I had a pc-v on my 07, but it came from fuel moto, and they were the only source for maps, as well. Dynojet sells the PC-V for 09 and newer touring bikes, and the PC-III for the 08 and older bikes. I though fuel moto was the only source for PC-V for the 08 and older touring bikes.
The folks at more power said it will work..do it all the time..I double checked due to the fact of seeing that at fuel moto and dennis kirk's site said it did not work.
