front caliper removal??
Not sure about your '99 but I had to drop the front wheel on my '11. It was kinda tricky because you can't get the caliper off with the wheel on and you also can't get the wheel off with the caliper on. Drop the wheel just a little and then remove the calipers. Put a rag over them because I guarantee they will either bump your wheel or your fender.
I take the calipers off of my rkc by unbolting the caliper mounting bolts and rotating the caliper to the rear a inch or two and twisting the caliper a little to compress the pistons while pulling off the rotor. It's a tight squeeze but they come off without damaging the fender. I not sure if this will work on your eg though.
