Is your rear valve stem ever down when you park?
Old May 20, 2012 | 03:32 PM
TUCCI's Avatar
TUCCI
The angled stems are where I'm going in the future, but for now I pull my jack under it and line it up so I the valves are between 5 and 7 oclock.
RBWIDE's Avatar
RBWIDE
Originally Posted by ClassicBill
And why couldn't they have it come out at an angle instead of straight up? what a PIMA! even with a flexible hose air guage the rotor is still in the way of my hand getting close enough to push the guage squarely on the valve.
There is a valve made like that..saw a link to it here just the other day..anybody recall that one? I was thinking about grabbing one before my next tire change, but forgot to note / bookmark it.
Old May 20, 2012 | 03:38 PM
WolfDog's Avatar
WolfDog
This is a funny question, I had my limited on the jack last month before it went on a 1400 mile ride upto and through Arkansas, week after I got back, gave it a well derserved bath, pulled it in the garage and lifted it back on the jack to detail it an noticed both valve stems were centered on the bottom just as they had been when I checked tire pressure before it hit the ground for our trip.
So yea, mine are turing up on the bottom centered.
Old May 20, 2012 | 03:47 PM
RBWIDE's Avatar
RBWIDE
Found the angled valve stems. Forum search is your friend.
Old May 20, 2012 | 10:16 PM
OLD 96's Avatar
OLD 96
I use a white metal marker to make a line on the side wall of the rear tire to mark where stem is. Like was said stem is never down when we park. And that stem is hard to see. White line on the side wall helps to find stem.
Old May 21, 2012 | 06:09 AM
RK Joy's Avatar
RK Joy
Your post made me laugh because it seems to me it seldom works out that way. You probably are like me and keep and eye on tire pressure before rides. Touring bikes make that hard. I came back from a long ride yesterday, backed into the garage and guess what? Front AND rear both down! Yay!
Old May 21, 2012 | 06:26 AM
OzarkHarleyguy's Avatar
OzarkHarleyguy
I didn't like that little boogar sticking up so I cut it off. Looks a lot better now since I chromed over it.
Old May 21, 2012 | 06:51 AM
TKDKurt's Avatar
TKDKurt
Try it on an RKC where it short and hidden between the spokes so it is almost impossible to reach.
Old May 21, 2012 | 07:49 AM
fabrik8r's Avatar
fabrik8r
Next time it's up on the jack, rotate the tires so both valves are pointed in the same direction before you let it down, that way in the future when you check tire pressure once you get one rolled into an accessable position the other will automatially be lined up. Maybe there is a market for a digital valve stem position indicator, with a little light on the dash. But seriously, We could employ some elements of the design of modern CTIS and put a valve stem in the end of the axle, no more access problem, next issue.
Old May 21, 2012 | 07:52 AM
FenderGuy53's Avatar
FenderGuy53
Chances are good that you'll need to roll it some to get to 6 o'clock position.
One thing I DID do the last time that I had it on the lift was to align BOTH valve stems to 6 o'clock. That way, there's a good chance that when I align the front, the rear will be accessible too!
