How often do you change your plugs and which do you prefer? I've tried both stock and the Iridiums (with about 9000 miles on the current set). I've found threads about which plugs, but not longevity. Opinions welcomed!!! Thanks...
I've got 42,000 on my original plugs I have had a new set laying around for a while but everytime I pull these they look brand new. Regapped them .01, very little wear
modern ignition systems and efi lead to long plug life.
mileage numbers are difficult to compare as the wear on a motor of 9000 miles on the interstate may be equal to 900 miles in town.
I use stock plugs as "new, awesome, performance" plugs may not interact well with the ECM giving spurious readings with could activate anti-knock timing retard.
I do use 'awesome' plugs on my panhead as the inconsistencies of the 6 volt system ( weak spark) and coarse carburation sometimes require a better electrode material to burn through the crud.
The actual plugs I have are the Screaming Eagle plug. I was a bitlery about using a Non-HD plug for the reason cited. I still have my OEMs. I can also see where the type of riding can affect the longevity as well. I guess I'll pull the plugs and see how they look and if good, clean, regap and reinstall. Thanks...
The E3s only had a couple thousand miles on them . Maybe 6/8 months on them. (bad weather here). I replaced them with
On a couple of the cars/trucks I have owned, changing plugs is a lot of work. On my current Jeep.... you actually have to remove the intake manifold to change spark plugs...!!!
My Harley plugs, by contrast, are cheap and very easy to change...
I just buy the OEM plugs (or Champion RA8HC) and replace them regularly... I change them every two years.. That translates to low mileage on two of my bikes (5k to 6K), and about 10-15K on the touring bike....
That makes it real easy to keep track of when they are changed, ensures they are always in good shape, and as mentioned, isn't expensive or hard to do..
