ABS Wheel vs Non ABS Wheel
08-25-2012, 05:32 PM
Ive got 2012 SG without ABS, can I put an ABS wheel on it without any problems?
08-25-2012, 05:35 PM
It's not the wheel that's different it's the bearings. Another way of putting it is YES.
08-25-2012, 06:08 PM
Yes, you'll have to change out the left side bearing.
08-26-2012, 01:24 AM
I just swapped out bearings. I had to change left front and right rear to put non abs wheels on a abs bike. The bearings you change out are on the side with the sensors for the abs.
Matt
08-26-2012, 11:26 AM
Quote:
Originally Posted by
DTTJGlide
ABS bearing on rear is the right side bearing. I've never looked closely at these bearings from a comparative standpoint. Are they physically different sizes?
08-26-2012, 12:10 PM
08-26-2012, 04:41 PM
Bearings are cheap and easy, but I just didn't know if it would bolt on with the ABS sensor instead of the spacer.
Thanks Guys
Dynaglide92
Wheels/Tires
03-25-2019 08:01 AM
riderboy1961
03-20-2018 01:03 AM
2004NIGHTRAIN
02-16-2014 10:03 PM
limj23
07-27-2011 06:38 AM
cfoster80
02-09-2009 11:01 PM
