Hot/Switched Wires in Nacelle
I'm installing a RoadTech radio on my 2007 RK and was wondering if there is an "always hot" wire somewhere in the nacelle? There's an unused orange/white switched wire which I need, but the installation requires a always hot wire as well. I'm not sure of the amperage draw, saw I don't know if any old hot wire will work. Should I just chase a hot wire from the battery?
Thanks for the advise. I think I'll run a wire from the battery for the reason Glockmeister noted. I also found some links that people have installed wiring to the head by running the wires under the speedo console. I'm going to do a mock up first before committing as the wires may have a tendency to rub against the tank. Also need to run the antenna wire through there as well. If it doesn't work out cleanly, then it looks like I'll need to pull the tank and run it along the main wiring harness.
