Load equalizer
Old Dec 13, 2012 | 09:06 PM
Roger That's Avatar
Roger That
I did not. I bought mine as a kit and has only one equalizer. No power or ground wires. I didn't even disconnect the battery like it tells you to before plugging it in. No issues. They work great!
Old Dec 13, 2012 | 11:18 PM
hattitude's Avatar
hattitude
Originally Posted by limboglide
If adding LED turns front and rear, do you need two equalizers?
No........ only one equalizer, installed between the TSM or TSSM plug and the rear lights plug, is needed to keep things working properly.
Old Dec 13, 2012 | 11:51 PM
White Ice's Avatar
White Ice
I bought the H-D LED's, no equalizers required.
Old Dec 14, 2012 | 06:43 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
For safety sake, pull the main fuse for EQ install. Easier than battery IMHO.
Old Dec 14, 2012 | 07:01 AM
pexcomike's Avatar
pexcomike
Mine came with two...one for the back lights and one for the front pair ...used both as per the instructions....Kuryakyn brand
Old Dec 14, 2012 | 07:26 AM
IHC67's Avatar
IHC67
Originally Posted by TheGrandPoohBah
The Biketronics is the plug 'n play one, does not require a power supply wire.
Easiest one I've seen, lifetime warranty, mounted by the battery on my '11RKC.
+1 this is the one I got too. Plug & Play. and its not your typical load equalizer that generates heat. I think they call it a load stabilizer or something, but it does the same job without worrying about where not to place so it doesnt melt wires. most equalizers generate heat.
Old Dec 14, 2012 | 07:40 AM
BigGdawg's Avatar
BigGdawg
No. Just one equalizer will take care of all 4 turn signals.
Old Dec 14, 2012 | 09:09 AM
bobgv's Avatar
bobgv
Biketronics true plug and play into the connecter under the left side panel. No heat and no battery wire either. Lifetime warranty and takes care of all your directionals.
Old Dec 14, 2012 | 09:45 AM
limboglide's Avatar
limboglide
Ok then, one equalizer for all signals. Thanks all.
Old Dec 14, 2012 | 10:06 AM
hattitude's Avatar
hattitude
Interesting..... never heard of any LEDs needing two....... doesn't make sense to me, but I'm not an electrician.
