had a slight problem cant explain?
Old Jan 16, 2013 | 01:25 PM
rick's Avatar
rick
Default had a slight problem cant explain?
About a week ago i was on my way to Marco Island and as im riding the bike just kind of stalled,the engine didnt stop it actually was still reving but i wasnt accelerating.I hit the throttle and nothing.Like wasnt getting gas.The engine light came on and i just pulled over and shut down the bike.Waited a second started right up no engine light and continued on my way 80 miles to Marco.Came back without a problem either.What happened? if anyone could explain,did i have some time of failure that eventually just reset or corrected itself?Anyone have a similar experience.
Old Jan 16, 2013 | 03:21 PM
FLTHarleyman's Avatar
FLTHarleyman
Put it in diagnostic mode to check for any locked in trouble codes
Old Jan 16, 2013 | 08:02 PM
The Old Man's Avatar
The Old Man
I think that the electronic throttle went into the limp or get home mode. It. Would have been a loose wire. Check for some codes.
Old Jan 16, 2013 | 08:04 PM
misinlink's Avatar
misinlink
TT418A service bulletin applies to 2008-Later Touring, Police & Trike Models
Symptoms: Driveability or Performance Concerns; Abnormal or Erratic Mechanical Operation; Intermittent or Erratic Electrical Operation.
Note: Throttle Position Sensor (TPS) circuit DTC's P0120, P0220, P0122, P0123, P0222 and P223 should take diagnostic priority over a P2135 code. If any of these TPS codes exist concurrently with the P2135, they should be investigated first using the diagnostic manual.
The TCA has two potentiometers (designated as TPS1 & TPS2) and a electric DC motor for controlling the actuation of the throttle. The two TPS sensors work opposite of each other. As the throttle plate opens , TPS1 voltage ranges from 0.0-5.0 Volts, while TPS2 voltage ranges from 5.0-0.0 volts. The sum of the two TPS voltages should always measure approximately 5.0 volts. These wire are: TPS1, pin # 37 (BN/V wire) of the ECM, and TPS2 pin #36 (BN/R wire) of the ECM
The TPS1 and TPS2 sensors should never add to more than 5.13 Volts Direct Current (VDC) or less than 4.87 VDC . A sum of voltages out of this range should register a current P2135 code.
Troubleshooting:
It is believed that FRETTING CORROSION is a major contributor of this code. A poor connection at the Throttle Control Actuator (TCA) can affect the sensor voltages reported to the ECM and this will set this DTC. As you can see from the General Information section, the sensor voltage only need to be altered by 0.13 VDC to possibly set the code.
The most common vehicles to have these symptoms are those with more than 8,000 miles (12875 Kilometers) or 103 cubic inch and larger engines. Vibration is believed to contribute to the FRETTING CONDITION.
Repair Procedure:1. While monitoring the TPS1 and TPS2 voltages on Digital Technician 2 (DT 2), wiggle the TCA [211] and the ECM [78] connectors.
2. If the voltage changes while wiggling the ECM connector , replace the affected ECM terminals (part # 72605-08). These wires are: TPS1, pin #37 brown/violet wire of the ECM, and TPS2, pin #36 brown/red wire of the ECM.
3. If no voltage change is noted while moving the ECM connector , the connection issue could be in the TCA. Replace all socket terminals with NEW terminals (part # 72663-11, used in current production) at the TCA connector[211B].
4. BEFORE CONNECTING the TCA CONNECTOR, clean the male TCA pin terminals with a swab and alcohol, and ASSEMBLE WITH DIELECTRIC GREASE.
DTC P2101
General Information: The TCA contains two potentiometers (designated as TPS1 & TPS2) and a electric DC motor for controlling a actuation of the throttle. TPS1 & TPS2 are mounted in the TCA. They are connected to the keyed shaft of the throttle plate and used to communicate the throttle plate position.
Each TPS supplies input to the ECM in response to the position of the throttle plate. The ECM activates the motor in the TCA to move the throttle plate, based on signals from the Twist Grip Sensor (TGS). When the ECM send voltage modulations to pins 2 & 3 0f the TCA to move the throttle motor, it checks fo subsequent TPS1 and TPS2 voltage changes. If it does not sense TPS changes it will set this code.
Troubleshooting: First verify that the throttle plate moves freely when engine is not running. If it does not the TCA needs to be replaced.
Poor ECM connections seem to be the most likely cause. Be aware that this issue may be aggravated by the seat pan making contact with the ECM connector. In most cases, this is caused by the installation of an aftermarket seat.
A poor connection at ECM pins #29 & 30 could cause an interruption in voltage to the throttle motor and set this code. Similarly the ECM uses voltage from pin #52 yellow/green wire to supply power used at pins #29 & 30 and could cause the same symptoms.
Repair Procedure:
Identifying the connection issues at this location may be difficult.
1. Replace all socket terminals with NEW terminals (part #72663-11 used in current production) at the TCA connector [211B].
2. BEFORE CONNECTING the TCA CONNECTOR, clean the male TCA pin terminals with a swab and alcohol, and ASSEMBLE WITH DIELECTRIC GREASE
__________________
Old Jan 16, 2013 | 08:49 PM
smithbrl's Avatar
smithbrl
Limp mode.
Old Jan 16, 2013 | 08:53 PM
dickey's Avatar
dickey
Not really sure as I am not familiar with TBW issues. But...
I was wondering--is that color stock on your RK? Never seen it before except on a Sportster. Looks really great.
Old Jan 17, 2013 | 09:49 AM
rick's Avatar
rick
Yes it is thanks.Only available apr-may 08 i believe.2008 RKC.
tensaw
Jun 3, 2018 11:40 PM
mtowe
Jun 3, 2018 01:15 AM
drew4jan
May 23, 2018 02:11 PM
FireHogRider
Electrical/Lighting/Alarm
18
May 4, 2017 11:37 AM
trackadaptor
Aug 21, 2012 10:33 AM
