Heat wrap
Old 02-06-2013, 01:14 PM
oricko's Avatar
oricko
oricko is offline
Default Heat wrap
Has anyone ever used the fiberglass heat wrap under heat shields, and if so did it cut down alot on the heat against your legs
Old 02-06-2013, 01:44 PM
Frankenbagger's Avatar
Frankenbagger
Frankenbagger is offline
Ive only used it because I didn't have heat shields at all. Ive experienced that heat shields or fiberglass/titanium wrap are each pretty effective on their own, but never tried to combine them.. I dont know if the benefit will be worth the headache of wrapping the pipes and trying to fit heat shields over it. Also, any brackets that rub on the wrap will cut right through it, and once its cut it all unravels and needs to be redone. I could see the tabs on the back of the heat sheilds or just the edges of the heat shields being a problem.
My $.02 is to stick with the heat shields
Old 02-06-2013, 02:42 PM
blackjeep's Avatar
blackjeep
blackjeep is offline
I tried it and didnt make much difference
Old 02-06-2013, 04:33 PM
the warden's Avatar
the warden
the warden is offline
This will only serve to insulate the exhaust and make your engine that much hotter. Bad idea. they run hot enough as it is. If you have a cat in your exhaust, decat it or get an aftermarket head pipe without the cat. Will significantly reduce heat and will perform much better. You will also need to consider a fuel management system programmer if you change out your exhaust.
Old 02-06-2013, 05:21 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
I have heard either do one or the other.
Combined with both the exhaust wrap and heat shields will do MORE damage then good.
Not sure what scoot you have, or year. But if it's a 2009+, get rid of the cat, and you will see a big difference from the heat!
Tuner (of choice) and a stage 1, different headers and you will notice a better running, better mileage, and less heat.
YB
Old 02-06-2013, 05:36 PM
Justin Kelly's Avatar
Justin Kelly
Justin Kelly is offline
A buddy of mine did this to his 2012 Ultra. Didn't make a big enough difference. He ended up changing out his head pipe and putting SERT on it and is totally happy with it now! I have 2010 Street Glide and I just decatted mine and put on PCV but have not had it out yet.
Old 02-06-2013, 05:37 PM
Ocgreenmachine's Avatar
Ocgreenmachine
Ocgreenmachine is offline
I had fiberglass heat wrap under the heat shields of my Vance and Hines RSD Tracker exhaust and it actually made it a little worse. The gap between the heat shield allowed air to cool the heat shields while I was riding and the fiberglass wrap eliminated the air gap, which in turn eliminated the air cooling effect. I ripped the heat wrap off the pipes and it is much better now.
Old 02-06-2013, 07:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is online now
i tried it ,not much help,it was easy and the heatsheild clamps held it in place,BUT it rusted the head pipe bad in 2 years.went to a 2-1 and a good tune much better results.
Old 02-06-2013, 07:32 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I wrapped the stock non-cat header under the shields on my '09. Really can't tell any difference?
Old 02-07-2013, 09:38 AM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
The exhaust system is downstream of the combustion process, external to the engine; How does exhaust wrap make youe engine hotter?
Quick Reply: Heat wrap
