dakota digital led gas gauge problem
Old 03-09-2013, 08:26 PM
foundry guy's Avatar
foundry guy
foundry guy is offline
Default dakota digital led gas gauge problem
installed dakota digital led gauges on 2010 road glide custum. look great but gas gauge just blinks 00. Hooked up wires turned on key and 00. turned off key then tried again, turned key on & gauge read an accurate 4.1 but a second later it just started declining until hitting 00 again. never has registered anything else since. the oil temp reads great. any ideas? thanks
Old 03-10-2013, 12:37 PM
foundry guy
Default dakota digital led gauges
anybody else installed them?
Old 03-10-2013, 01:20 PM
Northwoodz's Avatar
Northwoodz
Northwoodz is offline
I did it many moons ago. If I remember correctly it's not just a plug-n-play. It has to be calibrated, but that should have been covered in the instructions. Contact DD and they can walk you thru it.
Old 03-10-2013, 11:01 PM
hockey8787's Avatar
hockey8787
hockey8787 is offline
Did you select the proper sending unit for your year bike!!
Old 03-11-2013, 11:53 AM
foundry guy
hockey, yes it is the right unit. northwoodz, you are right. my buddy is an excellent mechanic but not as great with reading instruction manuals if necessary. after talking with dakota tech we found out the problem. he skipped over the page with calibrating instructions. i am going to calibrate it this evening. thanks for your help.
Old 03-11-2013, 04:56 PM
foundry guy
Default gas gauge works
just finished programing the gas gauge. very easy when you read the entire manual. thanks northwoodz & hockey
Old 03-11-2013, 07:11 PM
hockey8787's Avatar
hockey8787
Anytime glad to help!!
parag
Electrical/Lighting/Alarm
06-09-2019 09:17 PM
GoldenOne86
06-04-2014 12:57 PM
pettifogger1
05-04-2014 07:37 PM
PKellyMc
06-22-2008 07:28 AM
firestar99
09-01-2006 11:01 PM
Quick Reply: dakota digital led gas gauge problem
