Tour pac and saddle bag led spoilers.
I just bought the full set up and need some advice on install. The instructions both say to hook them to the plug under the seat. They way i want them to function is run brake on the tour pac and run turn signal on saddle bags. And help would be greatly appreciated.
The saddlebag led's are easily wired as run, turn, and brake.
Find the connector under the seat and identify the wire colors for the turn signals and ground. Take the led wires; cut-off the excess wire; splice the ground woes of the spoiler led's to the.black ground wire in the connector; and splic one wire from each of the lid led's to the corresponding turn signal wires in the connector.
As for the wire colors, they are shown in HD's service manual which you should have for projects like this.
FWIW-- I thought the saddlebag spoiler led's were a poor lighting addition given their cost. If you can install a BAL taillight, that's a vastly better choice.
Good luck.
Carl
Good luck.
Carl
Is this setup going on your street glide? If so then I would assume that the tour-pac is detachable. If you don't mind using the Acc switch, then i would use it for the tour-pac. The harness for that will work for Run-Brake. Or make up another disconnect junction and just tap into the rear light harness. Three wire's RED-BLUE- BLACK. This is what i did for my air-wing light. For the side lights. same thing but tap into the corresponding turn wire's. You may want to add a set of these for the turns.http://www.customdynamics.com/eclipze_module.htm. Do you have any other Led lights on the bike?
I just got done changing all of mine. Installed all CD components .
Tour-pac conversion with magic convertor.
triple play,signal stabilizer.
fromt and rear turns, rear light, both finder tips.
P7 all three holes.
P7 all three holes.
If you have an Ultra tour pak, you can use the TP''s wiring for the spoiler led-- I did that also since my TP is detachable.
HD seldom changes wire colors. Use the manual you have and compare the colors you need with what's on you bike; then confirm with a test light by checking functions.
Carl
Carl
Follow the directions and they work as run and brake lights. Simple plug into the accessory plug under the seat. for making them into turns as well you have to follow what Harleypingman stated above. You can get some duetsch connectors and make up a harness so that they are quick connect and there will be no soldering, but it will cost you a few more pennies.
