Check engine light question!!!!
Old Apr 24, 2013 | 07:23 PM
650droptop's Avatar
650droptop
Default Check engine light question!!!!
A bunch of mods were done to my 09 RKC
Apes, inter primary, full exhaust, SE stage 1
Etc.. It's back together and runs great
But the check engine light is on did it just pull
A code because everything was apart
Old Apr 24, 2013 | 07:25 PM
stro1965's Avatar
stro1965
No, disassembly and reassembly by itself won't cause a code.
Old Apr 24, 2013 | 07:33 PM
650droptop's Avatar
650droptop
Ok thanks
Old Apr 24, 2013 | 07:39 PM
dawg's Avatar
dawg
What's the code? Probably from the apes install
Old Apr 24, 2013 | 07:51 PM
650droptop's Avatar
650droptop
I dnt knw what code it is
Check engine light is on
Old Apr 24, 2013 | 08:05 PM
dawg's Avatar
dawg
So check the code(s) and that will tell you where the issue is if any. May just be a historical code and can be cleared and the engine light will shut off
Old Apr 24, 2013 | 09:06 PM
650droptop's Avatar
650droptop
Will do
Thanks
Old Apr 24, 2013 | 09:29 PM
650droptop's Avatar
650droptop
I was told only the dealer can check the codes
And clear them...True?
There's nothing I can buy to do it myself
First HD sorry for my ignorance
Old Apr 24, 2013 | 09:49 PM
stro1965's Avatar
stro1965
Check this out:
http://www.fuelmotousa.com/site/harleycodes.html
Old Apr 24, 2013 | 10:09 PM
craving94509's Avatar
craving94509
Same thing happened to me when I installed new levers. Check engine light came on. Dealer said I broke the tweaked (didn't break) the brake switch, and that caused the light.
