Noisy Tappets
  #91
Old 07-05-2013, 10:50 AM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
When i first got my dyna few years back i was used to mx 4 stroke bikes which dont make anywhere near the noise of a air cooled Harley. Now im used to it and like some folks r sayin on here, u are sitting on an engine that normaly makes lots of noise since the early 1900,s. So im just riding my 13 Ultra, which as 700 miles on it and was noisy from day one. Change oil on time and if something happens then so b it. Ya cant enjoy the bike if every time u go out, you are fixated on that Harley engine chatter.
  #92
Old 07-05-2013, 02:50 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Default Lucas Oil Stabilizer
Originally Posted by JohnnyC
No Noise here. Try Lucas Heavy Duty Oil Stabilizer treatment. My Indy told me about it and I have used it ever since with great results. Quiets a motor to a reasonable level.
I mention this over and over, sometimes a couple of times as this thread comes back up and many haven't really read all the way through it to read my earlier posts.
For the $12 cost you would use about 1/2 to 3/4 of the bottle. Often you can add it without having to drain off oil depending on how full your oil reserve measures to be.
Or change your oil to the recommended weight for the temps you ride in. A 20W50 is a very mediocre viscosity range. Summer riding in heat you need to run straight 50 or 60 weight ... look at your manual. I'm not making this up.
found this at the Lucas oil site - page 6-7 shows part # 10130
http://content.yudu.com/A1o9d0/PitSt...FCycleDivision
  #93
Old 07-05-2013, 03:08 PM
bagman1's Avatar
bagman1
bagman1 is offline
I hear the bible thumpers knocking on doors again!
  #94
Old 07-05-2013, 09:07 PM
fullautomike's Avatar
fullautomike
fullautomike is offline
Originally Posted by 00flstf
Hi!
My Fatboy with stage 1 shure does tick when warm, it is silent at idle but what I call noise-ish at medium high revs. Came across a video on the tube which pretty much has the exact same valve noise as my bike; http://www.youtube.com/watch?v=5V5gX...aqt0SROh1g36nT
Anyone think this sounds normal? I come from metric bikes for 19 years, so I am trying to get used to the Harley.
Oil is Pennzoil 20w50 - usually in the 45-55 degrees temp around here on average.
I hear the noise on the video, sounds like mine, but I think mine is no problem. Like many others said these are V twin air cooled motors between our legs. I was a bit surprised that I could hear the valve train noise when I got my Limited last year. I just figured there would be no valve train noise, but it is much quieter than my Sporster was. Now that was louder, but the motor was also built up. As far as our 103's go if I start to hear clunks, or knocking sounds or nasty metal to metal sounds, then I'll be concerned.
Today I rode 100 miles, 2 up in the lower 90's. Motor sounded just the same as it does in the cold. Not that it matters but I use Amsoil 20-50.
  #95
Old 07-05-2013, 10:34 PM
dulley's Avatar
dulley
dulley is offline
I agree ,I have a 2011 with the 103 and it was making a lot of tapping ,well I deciced to try lucas ,so I drain a half of qt. out then put in the lucas I say I lost atleast half my noise ,going on a 100 mile trip Saturday ,then I,ll know for sure
  #96
Old 07-19-2013, 07:47 PM
Red Eye's Avatar
Red Eye
Red Eye is offline
Got tired ears with the Screamin Eagle II pipes on my 06 Softail, so put on a used set of 07 stock pipes and mufflers.
Better sound for me and wife, but....
Valve clatter is ugly loud now that I can hear the engine.
I, too, will try some Lucas or STP oil thickener for sure.
  #97
Old 07-19-2013, 09:02 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I always put Lucas oil treatment in my bikes when I change the oil. I have no empirical evidence it actually does anything, but my ears say that it does. Every bike from my Shovels to this brand new 103 Twinkie I just bought, ran quieter after I added Lucas, and or a mixture of Lucas and STP engine treatment. Not sure even why I do it, but I am always falling for the hype. I always add concoctions or oil treatments to my engines and trannys, and I have always had good luck with them. I probably will continue to do so, but as long as they help...... its only money.
  #98
Old 07-19-2013, 10:03 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
If I had to choose between Lucas and stp the choice would be easy. Stp at least has some additives in it. Lucas has none. Not a huge fan of either, but ymmv...
  #99
Old 07-19-2013, 10:47 PM
Fathertime500's Avatar
Fathertime500
Fathertime500 is offline
Have been using my cell phone to record the tapping, must have had 7 or 8 different recordings. Service manager scheduled me in for replacement of the lifters next week, lucky me, all on their dime. Finally ....FT
  #100
Old 07-19-2013, 11:29 PM
mtgriz's Avatar
mtgriz
mtgriz is offline
Be sure and post back if you notice any difference. On my 103 I may get a tap or two right when I start it in the morning, but otherwise pretty quiet.
Quick Reply: Noisy Tappets
