SAE or Metric?
I tried to search for a post from last week and couldn't find it. Someone asked what size socket to use on a certain nut or bolt. Some replies came back with a metric response and others came back with a SAE response. I've noticed some nuts and bolts seem to be metric and some SAE. Does HD use metric or SAE on their rides?
Thanks
Steve
Thanks
Steve
ORIGINAL: Jonas
They use both. It is in possible to change front brake pads on 2004 RoadKing without having both SAE and Metric 12 point.
Just the battery I do believe. The Vrod is a different story though as I have no knowledge of them. It is easy to tell if it is a metric or standard though. The metric will have number for the strength and the standard will have markings like 3 markings mean it is a grade 5 bolt.
You can use some metric wrenches and SAE as the sizes are so close. You can use the 14mm instead of the 9/16 since the 14mm is a tighter fit. A 16mm is nearly identical as the 16mm. There are a few other sizes though close enough.
