How many links on my primary chain?
Old Aug 2, 2013 | 07:34 AM
fwb35's Avatar
fwb35
Default How many links on my primary chain?
99 EG Standard, am trying to find out how many links are in my chain and how much of a longer chain I will need by going to a 27 tooth compensating sprocket, anybody have this info?
Thanks
Old Aug 2, 2013 | 02:22 PM
djl's Avatar
djl
Thanks
HD introduced the Twin Cam engine in 1999; touring bikes were carbureted but there was also an EFI option. The carb bikes came with 3.15 gearing (25/36 primary) and the EFI Touring Bikes were given 3.37 (24/37 primary) gearing.
IIRC, the primary chain for both setups was the same, 82 pitch. The chain pitch required to accomodate a 27T motor sprocket will depend on whether your bike is currently geared with a 36 or 37 tooth clutch sprocket. You may not find a primary chain with the required pitch to accomodate your needs.
I would call Diamond or Tsubaki and chat them up. I would also be looking for an o-ring, roller chain. You may have to revert to OEM or aftermarket configurations designed to work with more standard configurations. Baker has a 28T sprocket/chain setup??
sgw1064
Jan 8, 2023 09:19 PM
Ready
May 24, 2019 07:47 PM
langlois1
Jun 25, 2009 04:52 PM
Hog Yild
May 10, 2008 10:31 PM
Shovelin dwn da road
Sep 24, 2007 01:58 PM
