7 inch Headlamp Trim Ring (part # 69627-99)
Old 08-19-2013, 08:52 PM
kryingame's Avatar
kryingame
kryingame is offline
Default 7 inch Headlamp Trim Ring (part # 69627-99)
For my SG, I changed out the headlight and went with the phase 7 Truck light.
At the suggestion of members, I changed the Headlight Bezel because the phase 7 sticks out a few inches further than the stock headlight.
I noticed that once the bezel is screwed around the headlight, although the screw and nut is secured, the headlamp trim ring is able to spin around.
Is this normal?
Thanks!
Old 08-19-2013, 10:24 PM
FLHTCU Owner's Avatar
FLHTCU Owner
FLHTCU Owner is offline
Is this normal?
Thanks!
No. It should not move at all. Did you remove the stock trim ring? If it's the same as mine, it fits over the stock trim ring.
Old 08-19-2013, 10:39 PM
kryingame's Avatar
kryingame
Oopsss. Thanks man. I now have it installed properly.
Old 08-19-2013, 11:18 PM
FLHTCU Owner
No problem. Make sure it's properly adjusted. Mine was pointing too far down after installation.
bman7163
2014-2023 Touring Models
02-17-2018 09:10 AM
twp98
04-03-2016 06:00 AM
billbuzz
03-11-2014 08:53 PM
foxtrapper
11-21-2013 12:44 PM
shagnasty
02-21-2010 09:47 PM
Quick Reply: 7 inch Headlamp Trim Ring (part # 69627-99)
