Chirping at Idle
Old Oct 2, 2013 | 11:33 AM
steelerdude1's Avatar
steelerdude1
Originally Posted by Guntoter
That sounds more like a squeak like something is rubbing metal to metal. Make sure the exhaust pipes are not touching anything metal and make sure the rear pipe is not touching the top of the primary case.
I agree, it doesn't sound like an internal engine noise to me. My guess is something like a bracket mounted with a bolt worked itself loose.
Old Oct 2, 2013 | 11:39 AM
cayers's Avatar
cayers
+1 for the muffler rubbers
Old Oct 2, 2013 | 11:45 AM
Greg Anderson's Avatar
Greg Anderson
Originally Posted by robknc
They are working on diagnosing the chirp today, so I'll hopefully know what the deal is this afternoon sometime. I'll post back. Seriously hope it's something simple.
Mine made a noise like that and it turned out my saddle bag lid was not on good. Missed one of the fingers opposite the latch. Just a thought...
Old Oct 2, 2013 | 12:23 PM
bzb123's Avatar
bzb123
I had a similar chirp a couple years ago.
Turned out to be the left floor board hinge bolts. Squirted a little silicone lube and it was gone.
Just a thought!
Old Oct 2, 2013 | 12:28 PM
fwb35's Avatar
fwb35
Mine was the rubber muffler mounts
Old Oct 2, 2013 | 03:24 PM
Barmats's Avatar
Barmats
You don't have a Guardian Bell hanging off the underbelly anywhere, do you?
Old Oct 2, 2013 | 10:54 PM
HDD's Avatar
HDD
Originally Posted by RoadHog659
I got rid of a chirping sound at idle by lubing the upper motor mount stabilizer with some light oil and snugging them up.
Had similar noise. This was the solution.
Old Oct 3, 2013 | 10:11 AM
sparky_mo's Avatar
sparky_mo
Originally Posted by dougbk
This has been my experience also. Add a little lube to the rubber and it will quiet it for a while.
I would bet anything this is where it's coming from. Lubing it will help for awhile but you might as well get out the kuryaken catalog and order a clamp set. You're gonna have to replace rear rubber mounts to get rid of it for oh a year or so and then do it again. You will be surprised how tight the new ones will be compared to the ones you're replacing.
Old Oct 3, 2013 | 10:26 AM
Duc's Avatar
Duc
I had the same noise, mine got bad enough I could hear it at low speeds drove me crazy.
It was the cross over, no matter how tight it was it still squeaked. To test IF it is your exhaust while it's running apply pressure to tip of tailpipe (did it with my foot) if it stops you know it's exhaust related.
What I had to do to stop mine was remove crossover, apply a couple wraps of metal tape, then reinstall.
Quite as a dead mouse now.
Clif
Old Oct 3, 2013 | 05:53 PM
Mikekoz13's Avatar
Mikekoz13
Mine was also the front motor mount.
