Twin Cam Striped Spark Plug Threads
I f' up today. replacing my park plugs the front head striped out. I had trouble with it being too tight before but today was the day. So to many thanks from this forum I ordered Time-Sert spark plug repair kit. Once I'm done I will post a review of the tool and how it went. I don't know how many spark plugs I have changed, this was the first time I striped the threads. Aluminum stripes real easy.
That may be so, but since Heli Coils are far stronger than the original threads, that would make Time Serts exponentially and unnecessarily "better", with a proportionately higher price tag. Helicoils are stainless steel so they would also "be there long after the aluminum is gone", whatever that is supposed to mean. HeliCoil has been the standard in thread repair for decades and I guarantee you will find more of them in machine/maintenance shops around the world than Time Serts. Buying and using the newest and most expensive tool for the job does not ensure the best repair. I would be willing to bet that even the cheapest clone helicoil spark plug repair kit will do the job sufficiently. There are not degrees of "repaired" for this application, its either fixed or not; does it hold a spark plug in place and retain compression? Then why spend more to do the same job?
Not exactly,standard thread sizes are drilled and tapped with special helicoil tap, slightly oversize but the same pitch as the original thread, the insert returns the threads to original size but stronger. The spark plug kit uses same type of duplex tap tool used by Time Sert, must be a decent technique since Time Sert copied it; it threads in with normal plug threads as a guide and the secondary tap cuts the insert threads. Actually the Time Sert requires an extra step to counter bore for the shoulder on the insert. Your Time Sert kit will make an excellent repair. All the demos are displayed as benchwork, to do this job on the bike it helps to have assistance, you can rotate the crank so the exhaust valve is open and apply compressed air at the muffler, air will flow out the plug hole, use a rag wrapped around a blow gun to make a seal at the muffler, this will keep tap chips blowing up and out of the tap flutes and no chips will drop in the cylinder. Depending on the exhaust type the other muffler may need plugged.
racerfranz (03-27-2018)
