best way to clean corrosion on lower forks?
Yea I plan on going with Chrome at a later date, but I'm looking to detail the bike in the meantime.
I'm not sure if they're coated or not, but I believe all were in 02. Won't see the bike until next Saturday. I don't want to break into the clear and make a mess of it unless I have to, not sure how its going to react to polish?
Anyone know the best way to clean?
I use Flitz with a toothbrush or one of the softer teflon scrubby pads, then a good carnuba paste wax to seal the pits were rocks, gravel and June bugs have pitted the anodizing. The carnuba wax lasts for the entire season unless you wash you bike with soap or detergent, then once the forks are dry, you have to rewax the leading edges. (soap cuts the wax, while salt oils just wipe off.)
This does not remove the pits. Small ones disappear completely and large ones become clean pits. If you do it more or less regularly, you don't get large pits.
Mostly once the forks are waxed, all I do is wipe it with a damp or wet soft cloth. I only rewax if I use soap on the entire bike.
If you have corrosion, then you need a buffing wheel as you have to resurface the aluminum. The coat it with clear coat, powder coat, paint, or wax.
I have used flitz metal polish with 0000 steel wool to get the clear coat off and made forks shine like chrome. It is a lot of work to get them cleaned up the first time. After that they required a little touch up with the flitz and a cloth a couple of times a year, but stayed pretty nice.
