Auxiliary lights & Turn Lights
I ride a 08 Road King, I took notice today my auxiliary lights are not working and my front turn signals are constantly solid. I did check to make sure I did not have the high beams on. The front turn signals do work correctly, but the turn signal lights remains solid after the turn is completed. Brake light and rear turn signals work fine. Any suggestions on this would be greatly appreciated.
your bike is working normal. on the rear you should have only the fender mounted taillight illuminated when riding, until you hit the brakes. the rear turn signals are only signals and should only illuminate when your turn signal is on. the front signals are also running lights and will remain solid at all times.
pay up cycles
08-13-2013 01:49 PM
NCCopBikeRider
01-25-2009 02:07 PM
