Does the new Twin Cooled 2014 Run Cooler-yes
Bought my 2014 Limited Sept 10. Still have my 2013 Road King for comparison. The day after I bought the Limited the temp was 96 degrees here. Did Highway and town traffic. The bike NEVER went on heat management and dont recall the fan kicking on even once. My Road King would kill the rear cylinder pretty often. About the 2nd or 3rd stoplight, it would do that. Put my digital oil temp dipstick in. Seems to run about 20 to 30 degrees cooler than my Road King and previous 103s did and much cooler than my 2011 110 CVO Ultra. I plan to continue checking that issue but as of now, yea it does run cooler. I may even leave the cat in this headpipe since I haven't had the cooked thigh syndrome my others created, and frankly I don't think that Cat was a significant flow issue, more of a felt heat issue. Our cars have been runnin Cats for many years.
That is what the heat management system does, it shuts off the rear cylinder, you can hear it at idle right away, it sounds like it's runnin on one cylinder which is just what it is. My Road King has a Wood 555 cam, V&H dresser duals and 4" Rineharts. I run a Supertuner in it and it IS well tuned by a knowledgeable pro. runs really good. My Limited now has a Stage 1 a/c, stock Headpipe, and SE Street Cannon slip ons. I'm running a FL VIED-10. Runs very well as well. Not sure how stock that Texas RK is running in 100 degree temps but are you sure your 2009 Road King has the heat managment system ? and if so, is it enabled?? I don't recall what year they started that and some bikes don't have it enabled and the rider doesn't even know it.
FYI Jamie from Fuel Moto documented that the 14 Limited's run about 30 deg cooler back in late Sept early Oct so its good to hear that your experience is similiar. From my observations my 14 Limited seems turns off the rear cyl. at idle whenever the ambient temp is over 80 deg. It sounded like several other owners reported the same thing that around 80 deg. it deactivates the rear cyl. My owners manual stated it is turned on based on cyl temp but others have said that is not correct. Do you know for sure your ettms? is turned on? You can turn it off.
That is what the heat management system does, it shuts off the rear cylinder, you can hear it at idle right away, it sounds like it's runnin on one cylinder which is just what it is. My Road King has a Wood 555 cam, V&H dresser duals and 4" Rineharts. I run a Supertuner in it and it IS well tuned by a knowledgeable pro. runs really good. My Limited now has a Stage 1 a/c, stock Headpipe, and SE Street Cannon slip ons. I'm running a FL VIED-10. Runs very well as well. Not sure how stock that Texas RK is running in 100 degree temps but are you sure your 2009 Road King has the heat management system ? and if so, is it enabled?? I don't recall what year they started that and some bikes don't have it enabled and the rider doesn't even know it.
So we have been dealing with Interstate stop and go traffic for some time in 98 degree plus heat. Even with the heat management My engine has gotten so hot that it has stalled. Yes, I do have a stage one installed and it does help so bur not in these conditions.
Received 3,961 Likes
Not sure if it is the same on the Twin Cooled, but on pre-Twin-Cooled the EITMS operates as follows-
Engine Idle Temperature Management System
For those riders who frequently find themselves in riding conditions where the vehicle is subjected to prolonged idle conditions or traffic congestion, the motorcycle is equipped with and Engine Idle Temperature Management System (EITMS) to provide limited cooling of the rear cylinder.
When engine temperature reaches a pre-determined point***, the EITMS will turn off the rear cylinder fuel injector. Idle speed will be maintained, however the rear cylinder will become and "air pump" which will work to cool the engine.
EITMS will activate (rear cylinder will turn off) when all of the following conditions are met:
Engine temperature is greater than 287 degrees F domestic (165 deg C international)
Twist grip opening is at idle
Vehicle speed under 1 mph (2km/h)
Engine speed under 1200 RPM
EITMS will disable (rear cylinder will again fire) if any one of the following occurs:
Engine temperature falls below 275 deg F domestic (135 deg C international)
Twist grip opening is greater than idle
Vehicle speed exceeds 2 mph (3 km/h)
Engine speed exceeds 1350 RPM
Clutch is released with vehicle in gear
When the engine is in EITMS operation, you may notice a difference in idle cadence. Additionally, there may be a unique exhaust odor. These are both considered to be normal conditions.
***The front cylinder head has a sensor, EITMS normally activates when this sensor hits 287 degrees F.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
