Value of PCV?
FM PCV for $300. Lifetime maps all 95% or better than dyno time. If you will change anything, pipes, A.C, cams, 107kit. any upgrades, you will get a new map that is 95% as good as a day on the dyno @ $95 an hour.
I'm running a PCV Retorfit on the 02 FLHPI, pulling 43+mpgs w/AutoTune. She is a Stage 3. Had to add AutoTune to get mileage up.
09FLHTP is running Stage 2 w PCV. stock F/M map for 103 w/Stage 1 and SE255's. Could not be happier! Loads more power from idle on up to 4K, where I shift, Same mpg's and I have been riding it harder with the new found power. Thinking I could pull AutoTune from the 02, install it on the 09 and dial it in! Maybe pull 45-48mpgd with it!
FYI, Fuel Moto PCV can save you some $$$ IF you are planning on any upgades. Their maps are 95% done. Npw and latter.
Dan B,
Central Ks.
Dan B,
Central Ks.
The electronics are as good as the guy tuning you bike. If you are having the flunky at the local shop dumping canned maps in you will get those results. If you have walter sprout, or equal, tune your bike you will get better results. I am not fimilar with the limitations of the se tuner or if it is comparable to the pcv in capabilities.
I went with the pcv from fuel moto. They loaded a map that feels pretty good and now that I added cams I sent my info in and they sent me another map promply.
is this clear as mud? Find a tuner and spend the $$$ to have a proper tune and use the tuner he prefers to work with.
Thank You
Mark
Received 70,928 Likes
No rush to sell. I still have other Road Glide takeoff parts to sell too. They're just collecting dust. I still have the inner fairing to sell among a ton of other things like stick ember red Sunglo saddlebags. No worries. Thanks.
