Headlight aiming suggestions.
Old Dec 21, 2013 | 11:20 AM
bagman1's Avatar
bagman1
Just remove the headlight ring from the housing and add shim washers to the top half of the headlight ring mounting bolts, Im guessing two on each bolt on the top half of the ring, this will tilt the whole bulb assembly towards the ground and you should have enough adjustment to level the light beam. If not enough add another washer, it wont affect the headlight ring because it attaches to the light housing can that you are moving out, it may show a larger gap at the top between the ring and housing but I bet you dont even notice it.
Old Dec 21, 2013 | 05:48 PM
bikerlaw's Avatar
bikerlaw
First, thanks everyone for the great responses!
bagman, this is pretty much what I did. It worked great. Because I have the frenched trim ring, you can not even tell. You have to look down and stare at the headlight itself to even notice its tilted in the housing. So, again, thanks for the input. Its working great now.
Old Dec 22, 2013 | 10:11 AM
bagman1's Avatar
bagman1
Awesome! Nothing like a simple fix. Merry Xmas.
richmac64
Sep 16, 2015 09:26 AM
jcmusic
Jun 17, 2010 04:27 PM
kk6pg
Aug 13, 2009 10:49 PM
rainman1977
Aug 8, 2007 11:33 PM
veniculum
Sep 8, 2006 12:18 AM
