How to remove bearings ?
Old 12-28-2013, 01:21 PM
rowle's Avatar
rowle
rowle is offline
Default How to remove bearings ?
Hi all
Is there a way to remove the wheel bearings without using the expensive puller ?
I have tried getting them out with a drift from the rear but dont have enough of a purchase to get them out..
I will be replacing them so not bothered about damaging them when getting them out.
Thanks all, have a great new year.
Rowle -uk
Old 12-28-2013, 01:32 PM
Jack the Machinist's Avatar
Jack the Machinist
Jack the Machinist is offline
6th Gear
I weld a washer to the inner race and push them out with a press. Works for me.
Old 12-28-2013, 01:46 PM
rowle's Avatar
rowle
rowle is offline
Hi'
Great idea but i dont have a welder....
Would a floor bolt work ? - one that expands and then it might be able to knock it out from the opposite side.
Thanks
Rowle-uk
Old 12-28-2013, 01:48 PM
lp's Avatar
lp
lp is offline
Received 2,756 Likes on 1,565 Posts
Be careful. You go knocking a bearing in or out and you can get it cockeyed and screw up your hub.
The correct tool is only 100 bucks on ebay. If you were near I'd let you use mine...
lp
Old 12-28-2013, 02:30 PM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
Been there done that, buy the tool, even if it's a cheaper version of it from Harbour Freight etc, you will be happy you did, it's worth it and you won't end up damaging something that will cost you a ton more to replace than the cost of the puller
Old 12-28-2013, 02:40 PM
oakmossy's Avatar
oakmossy
oakmossy is offline
bearing puller. get one.
Old 12-28-2013, 02:47 PM
williamfrog's Avatar
williamfrog
williamfrog is offline
Old 12-28-2013, 02:56 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
you can rent bearing pullers from autozone. best to use the right tool for the job.
Old 12-28-2013, 03:08 PM
rowle's Avatar
rowle
rowle is offline
Hi,
Thanks for the replies.
Its not so easy here in the UK as we cannot get (easily) harley tools and if we get them from the usa we pay mega import duty....
Rowle uk
Old 12-28-2013, 04:29 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
Originally Posted by rowle
Hi'
Thanks
Rowle-uk
A friend of mine use something like that a concrete anchor thing to push it out carefully from the opposite side without any problem , the bearings are unusable after that.
Quick Reply: How to remove bearings ?
